Go Back   NewTek Discussions > LightWave 3D Support > General Support
Reply
Thread Tools Display Modes
Old 11-06-2009, 05:31 AM   #1
Soth
Ha!
Soth's Avatar
looking for tutorials how to animate a crane
I need to do animation of something like that before Monday morning and to be honest have no idea where to start (need to rig it somehow).
I am so nervous, pls help!
__________________
Cheers
Tomek
GarageFarm.NET
100% Green CHEAP rendering!
Skype: GarageFarm.NET
Soth is offline   Reply With Quote
Old 11-06-2009, 05:57 AM   #2
melmoth2
Newbie Member
Quote:
Originally Posted by Soth View Post
What is it supposed to do in the animation?
melmoth2 is offline   Reply With Quote
Old 11-06-2009, 06:01 AM   #3
Soth
Ha!
Soth's Avatar
Rotate, slide, pick up things and this sort of stuff. What I will have proble is hydrulic arms. Those are linked to two models and I will like them to just slide out and in when I move whole crane around.
__________________
Cheers
Tomek
GarageFarm.NET
Old 11-06-2009, 06:46 AM   #4
Otterman
Angry Mac User
Otterman's Avatar
You might wanna have a dig around some of my posts-i do alot of this kinda thing...theres some simple rigs here that might give you some pointers
http://www.newtek.com/forums/showthread.php?t=101464
http://www.newtek.com/forums/showthread.php?t=79486
Otterman is offline   Reply With Quote
Old 11-06-2009, 06:46 AM   #5
daforum
da what?
daforum's Avatar
Have a look at these links:
http://www.newtek.com/forums/showthr...hlight=Pistons
ftp://ftp.newtek.com/multimedia/movi..._PistonRig.mov
They will hopefully give you ideas how to do what you need to do.
daforum is offline   Reply With Quote
Old 11-06-2009, 01:04 PM   #6
jeric_synergy
Axes grinder- Dongle #99
I did a crane very similar to that one once (hmmm, maybe I should sell it to you) , IIRC, I did the pistons with IK, pretty easy. Possibly just targeting would work too.
Getting the telescoping sections to work was tougher, and required Expressions. Basically, each subsequent section went out a percentage of its parent's extension. (I have no idea if that's how a real crane works, but it looked good.)
Parenting the HOOK to the end of the crane is fun too, since it never tilts-- it's HANGING. So you can't just parent it. I used Channel Follower, and erased the top of the "cables" using a clip map.
Oh yeah, good times. You'll have fun!
EDIT: I may have used Relativity for some of the things. Also, you can make your life easier if you set up the jacks to follow each other: then you only have to animate one jack and the other 3 deploy automatically.
jeric_synergy is online now   Reply With Quote
Old 11-06-2009, 01:13 PM   #7
shrox
Exposed to uranium 238
shrox's Avatar
I think it looks like it would be fun. I like to animate machines.
__________________
shrox
www.shrox.com
Why is it still moving? I shoved a stick through it's head.
shrox is offline   Reply With Quote
Old 11-07-2009, 10:51 AM   #8
JeffrySG
Pixel and Poly Pusher
JeffrySG's Avatar
A bunch of good links here too:
http://www.newtek.com/forums/showthread.php?t=97659
JeffrySG is offline   Reply With Quote
Old 11-08-2009, 07:57 AM   #9
MUCUS
Registered Mantis
MUCUS's Avatar
Why not just put a morph on the hydraulic pyston which will be driven by the pitch rotation of the crane? It should be really easy to control with cycler without any expressions I think.
MUCUS is offline   Reply With Quote
Old 11-09-2009, 01:25 AM   #10
jeric_synergy
And remember we have POSITION IK now, maybe some use can be made of that.
Old 11-24-2009, 07:38 AM   #11
Soth
Ha!
Soth's Avatar
Thumbs Up
Hi guys!
Thank you for all help. I have read everything and on top of it I bought RebelHill rigging tutorials. Than with all this knowledge setting up the scene and objects was no more than hour.
...and next time will take 15 minutes tops.
Click image for larger version
__________________
Cheers
Tomek
GarageFarm.NET
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 2000-2007, NewTek
