Go Back   NewTek Discussions > LightWave 3D Support > LW - ScreamerNet
Reply
Thread Tools Display Modes
Old 06-03-2004, 10:15 AM   #1
Matt
Valiant Knight
Matt's Avatar
Post ScreamerNet Video Tutorial
Despite writing a lengthy tutorial on the subject, I still receive quite a few emails regarding ScreamerNet, so to complement the PDF tutorial, here is a video tutorial showing how to setup ScreamerNet for Windows.
setting_up_screamernet.zip (12.5mb)
You'll need the TechSmith Screen Codec (TSSC) to view it.
You may also want to grab the PDF too, which goes into much more detail.
Hope you find it useful!
Regards
Matt
__________________
www.pixsim.co.uk - video tutorials, scripts 'n' stuff
Matt is offline   Reply With Quote
Old 06-03-2004, 02:06 PM   #2
Matt
Valiant Knight
Matt's Avatar
Okay, I've updated the video, if you grabbed the first one, this one is better!
setting_up_screamernet.zip (13.2mb)
Cheers
Matt
P.S. This is for Windows only, just thought you Mac guys might want to know before downloading!
__________________
Old 06-09-2004, 11:27 AM   #3
Darttman
member
Darttman's Avatar
Thank you for the post and link Matt
__________________
A box is a box, if it makes you money then its the right box
Darttman is offline   Reply With Quote
Old 06-09-2004, 04:23 PM   #4
bcgrafix
Won't play. Guess I don't have the codec?
bcgrafix is offline   Reply With Quote
Old 06-10-2004, 03:07 AM   #5
Matt
Valiant Knight
Matt's Avatar
Thanks!
You can find the link for the codec at the top of the thread.
Cheers
Matt
__________________
Old 06-10-2004, 01:05 PM   #6
bcgrafix
awww... man... only windows compatible... anyone have a converter, or something that will make it into another codec?
Old 06-11-2004, 01:24 AM   #7
jamesl
foofy bunny!
jamesl's Avatar
Well... it's a video about setting up Screamernet for windows...
__________________
james lloyd
sony pictures imageworks
jamesl is offline   Reply With Quote
Old 06-11-2004, 02:29 AM   #8
Matt
Valiant Knight
Matt's Avatar
You can view it on a Mac, Riki has successfully.
You need to download the Ensharpen Codec (which includes the TSS Codec) grab it here:
Ensharpen for OSX
Ensharpen for Mac OS9
Let me know if it helps.
Cheers
Matt
__________________
Old 08-09-2006, 07:58 PM   #9
zapper1998
I got to Go I got to Go..
zapper1998's Avatar
Hi Matt
I need some help please
Michael
__________________
Lightwave renders
3D CG Models/Animations
Spokane Wa, 99207.. You On the internet AGAIN, Enough Screwing around get Back to WORK......ugh..
zapper1998 is offline   Reply With Quote
Old 08-10-2006, 07:27 AM   #10
Matt
Valiant Knight
Matt's Avatar
Okay, go ahead, what can I help you with?
__________________
Old 08-10-2006, 09:28 AM   #11
zapper1998
zapper1998's Avatar
Ok, I have WIN XP Pro on 1 machine and Win 2000 Pro, on the other.
I followed your TUT to the letter, And Nothing is working with LW_9.
Have the Pluggins loaded and Read only..Autoscan is off.
Is there any thing I am missing, I checked the paths for the Configs and Content.
I would Love to get the Bloody thing to work some day....arrrgggghhhh...
How something so simple so can be so fustrating...
It works fine ( ScreamerNet) with LW8.5, Just can't get it to work with LW_9......
Thank you
Michael
Click image for larger version
ID:	35696   Click image for larger version
ID:	35697   Click image for larger version
__________________
Lightwave renders
Old 08-10-2006, 06:29 PM   #12
zapper1998
zapper1998's Avatar
Ok Got the ScreamerNet for LW_9, to work in WIN XP 64 Pro, except it does not save the Images to the Screamer_Save folder.
Any Ideas to why it won't save the images ????
Michael
__________________
Lightwave renders
Old 08-10-2006, 07:06 PM   #13
Matt
Valiant Knight
Matt's Avatar
Ahhhhhh, I think this is pretty straight forward, it looks like you've not enclosed the path names in quotes, ScreamerNet doesn't like spaces, so in your batch files make sure you surround your paths with " "
Your batch files should read:
@echo OFF
@echo "LightWave ScreamerNet Node 1 ..."
cd "c:\Program Files (x86)\NewTek\LightWave 3D 9\Programs"
Code:
LWSN -2 -c"\\64bitlightwave\S_Net_LW9_32\LightWave 3D 9\Config_SN" -d\\64bitlightwave\S_Net_LW9_32\LightWave_9\Content "\\64bitlightwave\S_Net_LW9_32\LightWave 3D 9\Screamer_Command\job1" "\\64bitlightwave\S_Net_LW9_32\LightWave 3D 9\Screamer_Command\ack1"
Also, just to point out the lines with REM in front are only to comment the script, they are not actually needed.
Let's know how you get on.
Cheers
Matt
__________________
Old 08-10-2006, 07:10 PM   #14
Matt
Valiant Knight
Matt's Avatar
You replied why I was replying!
The save issue could be an access issue, when on the other node (not the one with your full LightWave installed on it) can you access and save a file to the Screamer_Save folder?
Also, make sure your LW9EXT.cfg file in your shared config folder has all the plugins using the shared network address and not a local one.
Open it up in a text editor and check.
__________________
Old 08-10-2006, 07:23 PM   #15
zapper1998
zapper1998's Avatar
Ok got it running with saving the image files
I had a word missing,
"LightWave 3D 9" in the content string, oopppsss
Thank you so much, for your help, I have learned allot today.
Thank you
Thank you
Oh just a quick stupid question, How do I get LW_9 to save a .mov animation file, using screamernet???
Michael
__________________
Lightwave renders
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Copyright 2000-2007, NewTek
