Old 07-18-2010, 04:28 AM   #1
W-Tools
LWCAD tools feedback.
Dear LightWave and LWCAD users!
I've decided to start this public discussion, because I am going to reduce some abundant tools in LWCAD and need your feedback.
This thread is ONLY about LWCAD 3.x tools! (actual version is beta 3.592)
Please let me know your opinion about following topics:
1. Which tools in LWCAD are unuseful and should be totally removed.
2. Which tools should be merged into multi-function tools.
3. Which are the most useful tools in LWCAD for you.
Please try to be brief as possible as you can. And if you have any question which is not related to previous three point, please start a new thread or use support link on wtool3d.com.
Thank you for your help!
W-Tools is offline   Reply With Quote
Old 07-18-2010, 02:38 PM   #2
digefxgrp
digefxgrp's Avatar
Viktor-
First off I’d like to say I use a lot of LWCad in every modeling session.
Also, most of what I do is “entertainment” based, not arch-viz.
Most used LWCad Tools:
Snap Panel
Snap Move
Snap rotate
Snap Scale
Snap Mirror
Vector Clone
Knife Tool
Line, Rect, Rect3P, Circle, Curve, and Arc tools
Trim
Merge, Reduce, Close, Explode, and Join Curves
Extend
Fillet
Boolean 2D
Engraver
Profiler
Extrude
Offset and Mass Offset
Mass Round
Curve-to-Poly
Curve-to-LWCurve
Curve-to-PolyLine
LWCurve-to-PolyLine
Box and Box 3P
Bool
Cap Hole 2
Fix poly
Pattern 1D and 2D
USC Face and 3pt
Shape library
Occasionally used:
Point
Pline
Elipse
Chamfer
Thickness
Handle
Pipe
Cylinder
Tube
Drag and Weight
Array Tool
Radial Clone
Rail Clone
UCS Edge
Delete
Never used:
Roof
Floor
Window
Door
Fence
Stairs
Nail
Road, Road Lines, or CrossWalk
USC or Line Magnet
Jitter Tool
Select Random
Select Surface
Volume
Area
Make Convex
Analyze Curves
Point
Star
Ngon
DXF import/Export
Tools that could be merged together:
Circle and Ellipse
Fillet and Chamfer
Pipe and Handle
Box and Box 3P
Rect and Rect 3P
Window and Door
Roof and Floor
Thanks again for creating this fantastic suite of tools for LW!!
-Craig Paup
DigEfxGrp
digefxgrp is offline   Reply With Quote
Old 07-18-2010, 02:47 PM   #3
octopus2000
question: is LWCAD a plug in that gives lightwave an ability to support NURBs?
octopus2000 is offline   Reply With Quote
Old 07-18-2010, 03:04 PM   #4
cagey5
cagey5's Avatar
__________________
Your - denotes ownership as in - your nuts
You're - short for 'you are' as in - you're nuts
cagey5 is offline   Reply With Quote
Old 07-18-2010, 04:00 PM   #5
JBT27
What do I know?
JBT27's Avatar
I use all tools in the CadArchViz menu.
I use all the tools in the Cad Edit Modify and Multiply sections. Also the Reality tools.
I do not use so much the Edit (cur-pol) and Edit (cur) tools.
Fix and Analyze tools I do use, except for Analyze Curves.
I use all tools in Cad Primitives, but Primitives 3D not so much.
I use the Convert (cur) and Convert (pol) alot.
I think consolidating some tools is a good idea, like LW itself, in the name of efficiency. But I am dubious about ditching tools because everyone does everything sooner or later, and even the odd mostly unused tools are better there than not, because if they are not matched by some core function in LW, it would be a shame to lose functionality.
Julian.
__________________
http://www.take27.co.uk
Intel Core 2 Quad Q9550 @ 2.83Ghz
8Gb RAM
GeForce 9800 GT with 197.45 Driver
Win XP Pro x64 SP2
LW 9.6
JBT27 is offline   Reply With Quote
Old 07-18-2010, 04:33 PM   #6
wrench
Freelancer
wrench's Avatar
I'd like to see an option to replace standard LightWave tools in the process of installing LWCAD - I hate trying to remember why the snap isn't working because I'm just using the standard move tool instead of the LWCAD one. I don't mean to delete that functionality - it's not possible anyway - just to replace those tools in the menus and keyboard shortcuts, in short to make a LWCAD-optimised Modeler menu system (shame you can't add a preset to those Configure windows).
B
PS. Thank you Viktor for the excellent tools. Like Julian, I think consolidation could bring some benefits but would hate to say any deletion.
__________________
LightWiki
Liberty3D
wrench is offline   Reply With Quote
Old 07-18-2010, 06:28 PM   #7
Riff_Masteroff
Riff Masteroff
Riff_Masteroff's Avatar
" . . . , because I am going to reduce some abundant tools in LWCAD and need your feedback. . ."
Viktor: which tools are you intending to "reduce"? You post leaves me hanging on a limb because you request our input and do not counter with your own specific thoughts.
btw, I downloaded the beta a few hours ago, and will give it a going-over. Especially since I have needed to do work-arounds so that can make proper use of some tools such as mass round.
Riff_Masteroff is offline   Reply With Quote
Old 07-18-2010, 06:44 PM   #8
chunderburger
chunderburger's Avatar
Victor, I'd prefer to see tools relegated to a legacy tab in lw cad so nothing is gone and new tools replace or improve them.
I would like to see a snap tweak tool like XSI's
a snap lathe tool
UV support in tools
and handles on tools such as in XSI/maya
also the ability to use edge selections with the mass rounding tool
I would like to see tools be usable within the perspective viewport so we can model in perspective without other views.
check out maya/xsi's pivot manipulation system and xyz translations/rotation/scale tool handles
and a repeat last tool command that can be assigned to a keyboard shortcut
chunderburger is offline   Reply With Quote
Old 07-18-2010, 10:01 PM   #9
Snosrap
Snosrap's Avatar
Thanks Viktor for a great set of tools. Our shop does not use LWCad for archviz work. As it turns out LWCad is very useful in the furniture design field! It would be nice to see a few more developments to assist in that area. Number one would be having the ability to dimension objects and then create a .pdf, or adding the ability to create "drawings" similar to Inventor and SolidWorks etc. Also it would be nice if your tools remembered their last used parameters and by pressing the "n" key fired the tool with those last used settings, similar to just about every standard LW tool with the few exceptions like MultiShift.
__________________
Cheers
Snosrap
Jesus Christ is Lord!
Snosrap is offline   Reply With Quote
Old 07-18-2010, 10:20 PM   #10
digefxgrp
digefxgrp's Avatar
YES...YES...YES!!! This is a feature that is most needed I must say.
Old 07-18-2010, 10:59 PM   #11
3dWannabe
I don't own LWCAD, but I've been considering purchasing it. I can see that in addition to archviz, there are many features that would be useful in logo design and general modeling.
I bet there are many free tools that are only available in 32 bit (like some pixtrix plug-ins), or only available in Modo - or only partially supported or no longer supported at all - that provide unique features and ease-of-use for general Lightwave users.
It would be great to have those 64 bit and well supported.
As I'm just learning, I'm not the proper one to comment. But ... I bet most heavy users have their lists of non-CAD features that are 'must-have'.
LWCAD isn't an inexpensive product, and having more general modeling features (after all the must-have archviz features are implemented, of course), would certainly help tip me into purchasing mode.
3dWannabe is online now   Reply With Quote
Old 07-19-2010, 12:12 AM   #12
CaptainMarlowe
CaptainMarlowe's Avatar
Hello Viktor, and first of all, thanks for this great plug-in.
I'm modeling almost exclusively historical architecture, but mainly for hobby purposes.
Thus, LWCAD is clearly my primary tool in LW, especially since the beta has gone 64-bits on Mac !
To the topic :
- Tools I'd like to be removed : none
-Tools I'm using all the time :
all tools in primitives tab
all tools in arch viz tab
almost all tools in edit tab.
-Tools I'm not using so often :
fillet, chamfer, blend in edit (cur).
analyze curves
I have just downloaded the latest beta and not yet tested the new stairs tool, but I can already know it will come in handy for me !
__________________
Marlowe's website
CaptainMarlowe is offline   Reply With Quote
Old 07-19-2010, 01:53 AM   #13
logank
Most used:
Cad Primitives:
-Arc ,line,rectangle
-Curve to poly
CAD EDIT:
-all the modify tools
-vector clone
-Mirror tool
-mass round
CAD ARCHIVIZ:
-Engraver
-Profiler
DXF Import
I use Lwcad every modelling session .Great plug-in.
Gianmarco
logank is offline   Reply With Quote
Old 07-19-2010, 02:57 AM   #14
juanjgon
juanjgon's Avatar
First thanks for this great set of tools and your hard work.
I really cant find any tools i dont use sometimes, perhaps with the exception of only Dimensions and DXF tools. All tools inside LWCAD are useful.
A tool i miss i some kind of mixed poliline tool, like you have in Autocad. The tool could work like line tool, but with the ability to switch to curve or arc with OpenGL buttons, to draw complex polilines.
Best,
Juan J. González
__________________
Juan J. Gonzalez
Freelance technical and environment artist
juanjgon is offline   Reply With Quote
Old 07-19-2010, 03:56 AM   #15
meshpig
Muser
meshpig's Avatar
Quote:
LW specific 'non-uniform rational basis splines' AFAIK... lwcad is modeler on Steroids
__________________
9.6.1, i7 iMac 2.8 ghz, 4 gb, 512mb,10.6.4.
meshpig is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright 2000-2007, NewTek
