Go Back   NewTek Discussions > LightWave 3D Support > LW - Mac
Reply
Thread Tools Display Modes
Old 04-29-2003, 02:31 PM   #1
marlo.steed
marlo.steed's Avatar
Layout Lights inserted inside Modeler Lights
I know this may not be a Mac issue per se but Mac sorts tend to be more helpful - or so I am hoping.
The problem is this. I created a raft of physical lights in modeler for a city scape scene. Now I want to assign Layout lights to the modeled lights. Is there any easy way to assign lights in Layout to the physical objects created from modeler?
I know that I can go to the scence editor and make everything hidden, and then make the modeled light object visible so that I can more easily place the Layout Light in the right position but there must be an easier way when I have tons of lights to assign layout lights to. Is there any automated way to do this - I don't see anything in the documentation that would suggest a solution.
If this feature doesn't exist, it should - it would be a matter of aligning one Layout light with an object and then specify a list of objects that need lights assigned in exactly the same relative position.
Suggestions or work arounds would be welcome.
marlo.steed is offline   Reply With Quote
Old 04-29-2003, 02:43 PM   #2
Darth Mole
ShortsightedSithAssassin
Darth Mole's Avatar
Can you not use Luxigons? This adds a light wherever a Luxigon appears in Modeller.
In Modeller, select a Polygon and under Additional, select Add Luxigon, then choose the light type etc.
In Layout, under Scene>Generics, select Convert Luxigons. This generates a light at the centre of the selected polygon(s).
This should do the trick.
Darth Mole is offline   Reply With Quote
Old 04-29-2003, 02:47 PM   #3
Aegis
Gentleman
Aegis's Avatar
This sounds like a job for LUXIGONS!
1. Select a polygon to attach your light to (the light will face in the direction of the polygon's normal).
2. Go to Construct/Additional/Add Luxigon.
3. Choose the light type, shadow type, colour & intensity then click "OK" and send your object to Layout.
4. In Layout go to Layout/Plug-Ins/Generic Plug-Ins/Convert Luxigons.
5. If you wish you can clone your new light settings from a light already in your scene.
6. Give 'em a name and hit "OK".
Done!
__________________
"Special power!"
Andrew G. Morgan ~ CG Plumber
Survivor Films Ltd.
London, UK
Click here to email me!
Aegis is offline   Reply With Quote
Old 04-29-2003, 03:28 PM   #4
Darth Mole
Darth Mole's Avatar
I just said that.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright 2000-2007, NewTek
