Old 09-13-2005, 11:22 AM   #1
neilp
www.digitalcrush.co.uk
neilp's Avatar
subdividing sub patches???
I hope someone can help me, or point me in the right direction please.
Below is a screen grab of a golf course model where I have set my land plane mesh at about 9m x 9m, I would like to introduce more geometry into the hightlighted polygons (below) so that I can add a small sand bunker. When I subdivide or knife the polys the mesh breaks up with round edges etc. I could easily re-do the whole plane with a tighter mesh but I worry of my poly budget. is there a way to introduce more geometry with modification tools or maybe patch / weld the bunker in as a seperate piece. I'm stuck right now!!
__________________
i've got a doogy called 'BUSTER'
and a new puppy called 'Boris'
neilp is offline   Reply With Quote
Old 09-13-2005, 11:36 AM   #2
Earl
CORE Junkie
Earl's Avatar
SmoothShift is your friend in this case. Select the polys to be the sand bunker, use SmoothShift on them (best to do a single click without dragging - this will add geometry with no offset), then use the stretch and move tools to lower the inset.
Earl is offline   Reply With Quote
Old 09-13-2005, 12:45 PM   #3
FIREGIRL
Da Easy Goin' Kid
FIREGIRL's Avatar
I'm not sure if there are other methods that are faster but I like to use this one:
Hope that helps and good luck!
-Rachel
__________________
"Never forget that it is the spirit with which you endow your work that makes it useful or futile."
- Adelaide Hasse (1868-1953)
FIREGIRL is offline   Reply With Quote
Old 09-13-2005, 03:47 PM   #4
Surrealist.
Surrealist.'s Avatar
One thing that would make that a litte faster - more interactive anyway is the use of the control key, right clicking and the reduce selection hot key.
-Select Suppershift
-Hold ctl key/LMB drag to constrain to inset
-Right Click to create new geometry (same as unslecting and reselecting Supperhift)
-as geometry gets smaller, to reduce selection to the next row of polys use shift/[
Right click works on all of the tools like create box and even things like bevel and knife to create a new instance (activate) and thus geometry.
__________________
Richard Culver
LightWiki Subpatch Tutorial.
Subdivision Modeling Workshop
Surrealist. is offline   Reply With Quote
Old 09-14-2005, 03:41 AM   #5
neilp
neilp's Avatar
thanks guys,
you really got me out of a pickle, I use 7.5 at the moment - so supershift, I think, is not an optiion. I utilised Earls technique.....it worked a treat.
I will keep supershift in mind when i upgrade.
Thanks Firegirl for your troubles and Surrealist...sounds like a hot tip for all.
__________________
Old 09-14-2005, 06:04 AM   #6
Surrealist.
Quote:
Originally Posted by neilp
thanks guys,
Smooth shift I think is the version that comes with 7.5. Same idea except for the interactivity is different. Some people still prefer it I think based on the situation. Keyboard shortcut is shift f but not sure about 7.5 on that one.
Oh, yea, duh... that was earls origial idea. I think the right click still works the same on it though.
__________________
Richard Culver
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright 2000-2007, NewTek
