Go Back   NewTek Discussions > LightWave 3D Support > General Support
Reply
Thread Tools Display Modes
Old 10-18-2005, 11:10 AM   #1
Simercer
Changing the colour of points
Hi, im new to Lightwave and this form,, i know this is a basic Q but annoying if you dont know how, so how do you change the colour of the points in 8.3 from White which mine are now to something diffrent ??
Thanks Si
Simercer is offline   Reply With Quote
Old 10-18-2005, 02:16 PM   #2
MonroePoteet
I'm not sure what context you're talking about. Some possibilities are points displayed in the Modeler interface, points displayed in the Layout interface, the per-point color in a Color Map, colors of one-point polygons or Partigons in rendered output.
If it's for rendered output (pressing F9), a good start for changing the colors of things is the Surface Editor (shortcut F5).
mTp
MonroePoteet is offline   Reply With Quote
Old 10-18-2005, 03:39 PM   #3
Simercer
by points i mean vertices in the modeler, as their white and hard to see against a scaned image in the background.
Old 10-18-2005, 04:44 PM   #4
Orimar
Contended User
Hi Simercer:
Welcome. Try using the "Brightness" and "Contrast" controls in the "Display Options" panel (press "d" or Edit > Display Options) under the "Background" tab for whatever view port. Tweaking these sliders, adjusting "Image Resolution" and sometimes checking "Pixel Blending" and/or "Invert" has helped me often when there wasn't enough contrast between the backdrop image and the vertices.
Good luck and have fun.
.O.
Orimar is offline   Reply With Quote
Old 10-18-2005, 05:18 PM   #5
Surrealist.
Surrealist.'s Avatar
There is one other thing you can try too dependending on the situation - how complex the object.
You can turn on "simple wireframe points" in the display options panel in the interface tab and adjust the size which can help visability too.
__________________
Richard Culver
LightWiki Subpatch Tutorial.
Subdivision Modeling Workshop
Surrealist. is offline   Reply With Quote
Old 10-18-2005, 05:36 PM   #6
WizCraker
Beyond Reality
WizCraker's Avatar
this would be an excellent feature request. Sometimes even after playing with contrast and brightness I just can't see the vertex. It would be cool if we could change the color for the vertex to whatever we want kind of like the wireframe color.
__________________
ImageReality.com
"Relax...it's just an update for the patch to fix the nerf that nerfed the fix for the update of the patch that broke the fix that was fixed."
MacPro 8 Core 14 GB 3.2 TB 10.6.4
WizCraker is offline   Reply With Quote
Old 10-18-2005, 08:10 PM   #7
Surrealist.
I think that's comming up in 9.
__________________
Richard Culver
Old 10-18-2005, 08:52 PM   #8
Silkrooster
Silkrooster's Avatar
Quote:
Hey guys, I think you all miss read the post above.
The vertex color in modeler can be changed just go to DETAIL>POLYGONS>SKETCH COLOR This will change all objects if nothing is selected or just those selected.
You can also open the display options and set the default sketch color, anything created after this is set will be in the new color.
Hope this is what you were looking for.
Silk
Silkrooster is offline   Reply With Quote
Old 10-19-2005, 12:30 AM   #9
Surrealist.
Silk
I think by vertices he means points not the edges though, right?
__________________
Richard Culver
Old 10-19-2005, 12:44 AM   #10
Silkrooster
Technically a vertex is the edge.
Silk
Old 10-19-2005, 12:48 AM   #11
Silkrooster
I keep reading his post and now I am not sure. Perhaps he could clarify. The points in the corners of the polygon or the vertices (edges) of the polygon.
Silk
Old 10-19-2005, 03:22 AM   #12
Surrealist.
Silk
Oh OK. I was going off of this from the 3D Glossary:
Quote:
V (Vertex) Maps — V Maps is an abbreviation for vertex maps. V Maps provide additional information
associated with object points (vertices), like weight, UV and morph maps.
And if you look in a standard dictonary it cooborates my story.
__________________
Richard Culver
Old 10-19-2005, 10:23 PM   #13
Silkrooster
Interesting, I don't even recall where I got the info from any more. I'll have to see if I can find it.
Silk
Old 10-20-2005, 01:12 AM   #14
Surrealist.
Silk
You won't find it 'cause the info doesn't exist.
just playin'.
But seriously if you do look in a standard english dictonary you'll find that it maches the 3D definition pretty well in that it is the point where lines connect. I can kind of see where you are going though, I mean the edge is a series of "points" where the lines are connecting
Now when we get true hard edges in sub d then maybe we can change the definition.
Anyway, enough semantics. Would definately be interested if you can find that source.
cheers,
__________________
Richard Culver
Old 10-20-2005, 01:47 AM   #15
Silkrooster
Lol, Yeah I need to find the info. I hate it when I can't find it. Cause, I start doubting my self. That's not good. Any who, I start looking around.
Silk
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright 2000-2007, NewTek
