Go Back   NewTek Discussions > VT[1]-VT[5] > VT - General Support
Reply
Thread Tools Display Modes
Old 12-12-2005, 04:24 PM   #1
jsanfilippo
Tally control with Sony D50 ccus
I have 3 Sony D-50 ccu's and want to control tally.
I was reading old threads and it appeared that most users needed an aftermarket or custom built interface. But I know that the voltage swing changed with the SX-84.
Do any of you know the D50, and can you tell me if I can simply go from the SX-84 to my CCUs to control tally?
I also have Marshall V-R102DP-2C (http://www.lcdracks.com/racks/v-r102dp-2c.html)
with a three-way tally system. Any thoughts on how I would add them to the mix?
Thanks for any thoughts you might have!
jamie
__________________
Jamie Sanfilippo
Programming Pastor
The Meeting House
jamie.sanfilippo@themeetinghouse.ca
jsanfilippo is offline   Reply With Quote
Old 11-10-2007, 12:43 PM   #2
TRCC
TRCC's Avatar
Have you learned how to connect your D50 CCU to tally yet. I know your post is like 2 years old, but we have D50's and I'm in the same boat.
Thanks,
Luke
TRCC is offline   Reply With Quote
Old 11-10-2007, 12:57 PM   #3
PIZAZZ
NewTek Elite Partner
PIZAZZ's Avatar
Location: Texas, or wherever the plane drops me off this week
Quote:
Thanks,
Luke
When I get back to the office and have access to all my docs, I will post what we had to wire up recently. It depends on your PL/Com manufacturer.
Be back soon.
__________________
Jef Kethley
PIZAZZ
I make stuff work....
examples here... www.pizazzme.com
PIZAZZ is offline   Reply With Quote
Old 11-12-2007, 12:30 PM   #4
mhenstell
WNYF Television
Does anyone know the pinouts for the tally connector on the SX84? Is it in the docs anywhere? (sorry, I'm not near my VT system at the moment...) Thanks
mhenstell is offline   Reply With Quote
Old 11-12-2007, 02:27 PM   #5
jsanfilippo
I know i've seen a pinout diagram on this forum before. You could probably find it by doing some searching.
__________________
Jamie Sanfilippo
Programming Pastor
The Meeting House
Old 11-13-2007, 10:46 AM   #6
jcupp
Grizzled Veteran
jcupp's Avatar
We have a new tally light controller that will be shipping late this week, You can email me at jcupp@digarts.com for more info but if you want to roll your own:
Pin Description
1 LED 1
2 LED 2
3 LED 3
4 LED 4
5 LED 5
6 LED 6
7 LED 7
8 LED 8
9 GND
10 GND
11 No Connect
12 GPI Input 0
13 GPI Input 1
14 3.3 V Power
15 No Connect
The LED outputs are currect sinking (goes low when active) and you should use at least 200 ohm resistor in series with an external LED. There is also a 200 ohm resistor in series with this signal inside the BOB. These LED signals are just copies of the tally LEDs on BOB. The circuits gp logic low when activated. GPI pins are connected thru 200 ohms series resistance to the Microchip PIC16f872 micro controller I/O pins with a 25mA maximum current source/sink.
__________________
-Jeff
DigitalArts 800-692-6442
NewTek Elite Partner - Indiana, Illinois, Ohio, Michigan and Kentucky
Digital Arts
My Blog
metaSETZ Live Sets
jcupp is offline   Reply With Quote
Old 11-13-2007, 03:34 PM   #7
PIZAZZ
PIZAZZ's Avatar
It took me a bit to sort thru all the pdfs I have collected on this subject. Here is an edited version with the meat and tomatoes:
http://www.pizazzme.com/ConnectingIn...theSONYCCU.pdf
__________________
Jef Kethley
PIZAZZ
Old 11-14-2007, 12:44 AM   #8
lithiumpro
Dose anyone know if these outputs are isolated, or do we need to send them to a opti-culper or a Transistor to give some isolation. Or will we have any problems just hook up a led from the 3.3V to resistor to pin and thats it.
What is this about a PIC16f872 is that what is handling all the I/O inside.
lithiumpro is offline   Reply With Quote
Old 11-14-2007, 09:28 AM   #9
jcupp
Grizzled Veteran
jcupp's Avatar
My experience is that trying to drive the LEDs directly doesn't work too well. The SX-8(4) doesn't provide much oomph, the internal current limiting gets in the way.
__________________
-Jeff
Digital Arts
My Blog
metaSETZ Live Sets
Old 11-21-2007, 01:32 PM   #10
MikeS
This thread is just what I was looking for, but I was looking for info for tally with a JVC RM P2300 CCU. Any thought??
Thanks guys,
Mike Schwiebert
MikeS is offline   Reply With Quote
Old 11-23-2007, 05:12 PM   #11
PIZAZZ
PIZAZZ's Avatar
Quote:
Thanks guys,
Mike Schwiebert
I believe on that CCU you can do either a contact closure or voltage feed down the line to the Tally Lamp at the camera. You will need to refer to the technical manual for the CCU jumper settings for each mode.
I prefer to have the Tally Interface for the VT do contact closure if at all possible for the camera's CCU.
__________________
Jef Kethley
PIZAZZ
Old 11-23-2007, 05:25 PM   #12
PIZAZZ
PIZAZZ's Avatar
Quote:
● The TALLY lamp lights in red when contact is made between
the PGM (Program) and C (Common) terminals.
● The TALLY lamp lights in green when contact is made between
the PVW (Preview) and C (Common) terminals.
TALLY INPUT
The TALLY lamp on the front panel lights when signals are applied to the TALLY input terminals on
the rear panel.
PGM PVW C H C G
TALLY INTERCOM AUX VIDEO INPUT G
RTS
PGM (Program) terminal
PVW (Preview) terminal
C (Common) terminal
The RM-P210 has been set at the factory in the “make contact
mode”. If it is required to set it to the “voltage supplied
mode”, the setting of the internal circuitry should be
changed; consult your nearest JVC-authorized service
agent. (The modification will then be carried out with charge.)
NOTE
Well I was curious so I went ahead and confirmed what I thought was true. The CCUs you have are most likely set as they were from the factory with contact closure being the trigger to turn on the lamp. In our older RM300's at the church, there was a simple jumper inside to switch it between contact closure or voltage pass through.
Here is the link to the basic tech manual of the 200 CCU. Details quoted above are found on page 14 at the bottom.
http://books.jvcservice.com/Download...1002-003-H.pdf
You will need to purchase a Tally unit from Jeff Cupp, AmiTrace, or myself to interface between the VT and your CCUs.
__________________
Jef Kethley
PIZAZZ
Old 11-26-2007, 09:17 AM   #13
MikeS
Thanks, Jef. I'll give you a call.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright 2000-2007, NewTek
