Go Back   NewTek Discussions > NewTek Forums > General Discussion
Reply
Thread Tools Display Modes
Old 09-18-2006, 11:15 PM   #1
monfoodoo
Help on Finger joints
Under the request of a freind at work to do a Ravens Robot(50ish),here is where i,m at.Still in construction ,and while the simple ball and cup joint is used (i know that tehnically they wouldn't cut it as is),but i'm going with it.
My problem is that while he will not be animated,i would like to pose him.Using pivot points on the arm and leg joints works great,but on the fingers is this still the way to go? The finger joints can be the ball and cup or some other type of hinge. I havn't worked that out yet,but will have seperation as shown. Any help will be very welcome. scott
Click image for larger version
ID:	36994   Click image for larger version
monfoodoo is offline   Reply With Quote
Old 09-19-2006, 04:02 AM   #2
Dodgy
Worms no more! Free fun!
Dodgy's Avatar
If you want to just pose him, Using IK boost is a good way to go for fingers. You switch it on and can pull around any part of the hierarchy and it'll affect the rest. If you don't want a joint to bend in a certain way, set limits/ turn that channel off in the numeric panel and it'll respect them.
__________________
LaptopSetup:corei5 2.26GHz nvidia 230M 4Gig win7
HomeSetup:4 Ghz P4 3GigRam FX9600 WinXp
Dodgy is offline   Reply With Quote
Old 09-19-2006, 04:29 PM   #3
monfoodoo
thank for the reply.i boned out one finger and it works ok. as you can see the hinges overlay the next joint,i thought it would cause problems.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright 2000-2007, NewTek
