Go Back   NewTek Discussions > LightWave 3D Technique Discussions > LW - Third Party
Reply
Thread Tools Display Modes
Old 07-27-2007, 12:32 AM   #1
rinktoaster
Dynamite fire (fluid) settings question
Wondering if anyone using the Dynamite plug-in in fluid sim mode for a fire effect has found a good method to make flames dissisipate (become transparent) as they rise for a certain period or for a certain distance, like real fire. As with most fire sims, you can adjust this "life" property when using particles, but when using the fluid mode (which creates the best overall fire effect I think), the flames flow vertically forever for the full height of the sim box. The diffusion/dissolve setting seems to have no effect. I've thought about using the "Use LW texture" mode and selecting a gradient with distance from ground as the input, but the normal choices for input channel are not available.
Thanks for any help.
rinktoaster is offline   Reply With Quote
Old 07-27-2007, 06:55 AM   #2
Phil
Heffalump
The LW texture input puts hard edges on the volume. Your best option is the diffusion setting, I think, unless I am misunderstanding you. Diffusion has a strong effect here, at least for me. You do need to recalculate the simulation, though.
It has to be said that I'm somewhat frustrated that Can hasn't updated this plugin since release. I had hoped for a lot more.
Phil is offline   Reply With Quote
Old 07-27-2007, 08:21 AM   #3
rinktoaster
Phil,
Thanks for the info. Could you describe how you've gotten good results with the diffusion value? I'm experimenting with the settings on the "moving ball" fire scene that can be downloaded from Can's site. I've tried diffusion values from negative, zero, & positive, up to extreme values of +/-100,000 and see no difference in flame life/height.. the tendrils still boil up vertically to the top of the simulation box in all cases (always recalculating each time I change values of course). Wondering if other settings or modes need to be a certain way for diffusion to have any affect?
Old 07-27-2007, 05:23 PM   #4
Phil
Heffalump
I had a dose of config file corruption. I'm back on my feet and will endeavour to hook up something over the weekend for you. Nudge me by PM if I forget.
Old 10-08-2007, 02:59 PM   #5
eyelandarts
Bringing back this thread from days past. Have you guys had any problems using dynamite fluid mode and 9.3? Im having problems calculating a simple smoke stack for more than 200 frames when it goes all crazy.
Any help apreciated. Is there a place to go for dynamite Q's?
eyelandarts is offline   Reply With Quote
Old 10-08-2007, 03:34 PM   #6
Phil
Heffalump
No problems here with scenes up to 600 frames long. What kind of issues are you having?
Dynamite 1.2 is in beta at the moment...
Old 10-08-2007, 03:40 PM   #7
eyelandarts
Thanks for answering im using Dynamite 1.13b. How do I get 1.2? The problem im having is the fluid calculates as expected then suddenly the fluid just resets and tries to pick up from some other point in space. I dont remember the demo doing it so maybe I can calculate it in there and then use the cache from that one.
Old 10-08-2007, 05:46 PM   #8
Intuition
The Real Homestar.
Intuition's Avatar
Dynamite 1.2???? Gimme Gimme Gimme!!!!
__________________
KC
Digital Domain
BattleStar Galactica VFX
EdenFX
Intuition is offline   Reply With Quote
Old 10-08-2007, 07:42 PM   #9
RedBull
Heir to the Throne
RedBull's Avatar
Quote:
Email Can, and he is usually pretty good at that kind of thing, especially if you are having an issue with the current release build.
RedBull is offline   Reply With Quote
Old 10-09-2007, 02:44 AM   #10
Phil
Heffalump
Quote:
I'd be interested in seeing that - there are a few immediate possibilities to explain that, but it could also be a bug. Any chance you could email me sample content that shows this (without the cache file - that would be painfully large)?
phil{dot}stopford~at~googlemail[dot]com
Old 10-09-2007, 09:02 AM   #11
eyelandarts
Thanks for your help Phil...Sent!
Old 10-09-2007, 09:21 AM   #12
Phil
Heffalump
Cool. Give me a couple of hours to get back to you
Old 10-09-2007, 11:46 AM   #13
Phil
Heffalump
Hmmm. No mail arrived here yet.
Old 10-09-2007, 11:52 AM   #14
eyelandarts
strange, let me try again.
oops, yeah I ate the L in mail.
Old 10-09-2007, 12:35 PM   #15
Phil
Heffalump
Hmm. You are generating a huge amount of data with those settings. I changed the following :
cell size : 120 mm
X 30
Y 83
Z 30
Running the simulation generates a cache file of 2.3 GB and the simulation runs in a relatively short time. I'm wondering if you are simply generating too large a cache file.
I'm still poking around, but that's my gut feeling. Those changes don't show an issue and I haven't yet seen a crazy smokestack
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright 2000-2007, NewTek
