Go Back   NewTek Discussions > TriCaster > TriCaster Community
Reply
Thread Tools Display Modes
Old 03-10-2008, 11:47 AM   #1
JohnnyM
Smile Looking for good CAT5 Solutions
Hi There
We are in the process of setting up a mobile webcast unit, based on the Tricaster Studio platform.
We would like to run the cameras using CAT5 cables. We would take the camera output (Stereo Audio & S-Video/Composite) through a balun and then down cat5 to our Tricaster. We will be using mostly Sony HVR-Z1U cameras.
We would like to use Ethercon connections and heavy duty cat5 cable for this solution.
Here are my questions:
1) Does anyone sell or make heavy duty blaun boxes (S-Video & Stereo Audio)?
2) Does anyone know where I can get pre-made CAT5 cables with Ethercon connections suitable for this set up (500ft)?
3) Can you recommend any other solutions that might be suitable?
Your help with these questions would be greatly appreciated.
JohnnyM is offline   Reply With Quote
Old 03-10-2008, 12:15 PM   #2
PIZAZZ
NewTek Elite Partner
PIZAZZ's Avatar
Location: Texas, or wherever the plane drops me off this week
"You are a speakin my language" -- Men At Work
We developed a complete flexible Cat5 solution using a tactical grade Cat5 cable. It rolls as easy as a Canare or Mogami mic cable. The NCAA has been using our design for their DII Broadband streaming the last 2 years. Each cable is terminated with a Neutrik EtherCon connector that locks upon insertion just like an XLR. We use aluminum boxes on the cameras instead of plastic like most balun manufacturers do. The CameraBox can be Composite, SVideo or Component YUV. The CameraBox can also have a Tally light along with InterCom coming out of it.
Operational distances are up to 1000 feet. The NCAA routinely uses 500' for the field cam in football. There is now quality difference between 100' or 1000'.
With that in mind, I have a couple different ways to do the Cat5 solution.
1 cable we use for simpler projects is a single Flexible Cat5 cable. You can carry Composite or SVideo with stereo audio down 1 Cat5 cable. You can also carry Component YUV and Tally down 1 Cat5 cable instead.
Another cable we use is the same cable as above but paired with a twin in a single flexible jacket. This Cat5 snake is what we developed for the NCAA's DII streaming group. In the dual cable setup we carry video and audio on one Cat5 and then Tally/Intercom on the other.
Of course going with a single Cat5 cable would be less expensive than the dual cable.
The camera boxes would be priced as follows:
1 SVideo/Left/Right Unbalanced audio - $150
1 Composite Video/ Left/Right Unbalanced Audio - $150
1 Component YUV video/ 1 unbalanced Audio - $195
1 SVideo/Left/Right Unbalanced audio with Tally and Com - $195
1 Composite Video/ Left/Right Unbalanced Audio with Tally and Com - $195
1 Component YUV video with Tally and Com - $245
1 Rackmount or Desktop mount Breakout box for converting from Cat5 back to Video/Audio is - $295
Single Flexible Cat5 cable is $.95 per foot terminated with durable EtherCon Cat5 connectors.
Dual Flexible Cat5 cable is $2.25 per foot terminated with EtherCon connectors.
If you need Intercom, we sell tons of the Production Intercom gear to our clients. Production Intercom is interchangeable with ClearCom or Telex unbalanced PL Lines. 4 beltpack systems with power supply start at around $1000 See more details here www.beltpack.com
Let me know if you need any more information or have questions. I will try to find some pictures to post of our boxes for reference.
__________________
Jef Kethley
PIZAZZ
I make stuff work....
examples here... www.pizazzme.com
PIZAZZ is offline   Reply With Quote
Old 03-10-2008, 02:47 PM   #3
brians0105
I can testify for Jef's Cat5 products. We have the dual cable option because we send the following to each camera via Cat5:
- Component video
- Tally light
- Intercom
When we do sports remotes and don't need the component camera signals, we often run three composite cameras down one Cat5 box instead of 1 component camera.
These solutions save plenty of time and work, especially for remote productions!
Brian
brians0105 is online now   Reply With Quote
Old 03-10-2008, 05:31 PM   #4
JohnnyM
RE: Cat 5 Solutions
Thanks for the info guys.
Just wondering what you think is the better solution in terms of S-Video versus Composite. Typically S-Video has better quality than Composite, but I have read where there may be some latency issues when using a Y/C signal with Tricaster Studio. Any thoughts?
Do you have any photos of the boxes you could post?
Thanks for your help
Old 03-10-2008, 06:57 PM   #5
PIZAZZ
PIZAZZ's Avatar
There are zero latency issues with Y/C into the Studio. I am not sure why someone would of said that. All of the NCAA's gear was via SVideo instead of composite because we wanted to obtain the highest quality possible with the Canon GL2 cameras in the kits. You mentioned having Z1U cameras, you should use Component YUV anyway with them for the best quality into the Studio.
I am working on some pictures for you. I only had pics of the older design not the newer ones.
---- Brian, Thanks for the endorsement.
__________________
Jef Kethley
PIZAZZ
Old 03-20-2008, 03:08 PM   #6
bob anderson
I answered my own question.
bob anderson is offline   Reply With Quote
Old 03-20-2008, 07:07 PM   #7
LW_Will
Okay... so this CAT5 is not a packeted transmission (TCP/IP or whatever)... this is just using a CAT5 instead of a standard y/c or other cable, right?
__________________
Will Silver
Animator
digital TRiP
"Frame by Frame, to the EXTREME!"
Watch this space.
LW_Will is offline   Reply With Quote
Old 03-30-2008, 02:00 AM   #8
PIZAZZ
PIZAZZ's Avatar
Actually unknown to Mr. Brocato, we use a little bit of voodoo magic inside our boxes.
__________________
Jef Kethley
PIZAZZ
Old 03-30-2008, 11:54 AM   #9
ted
Member Of Many Adventures
ted's Avatar
We just ordered an awesome CAT-5 set-up from Jef.
As mentioned elsewhere, after helping Jef set-up a show in San Antonio, and realizing there wasn't much set-up with Jef's method and TriCaster, I knew it was the easiest, best method when we got our TriCaster.
Not only is it a great set-up, Jef and his team made it really easy to put together. They educated me on what I should order for what I wanted to do and are getting it to us in a rush for our next big job. (I hope!)
I wish everyone I tried to give my money to made it this easy!
Yeh, the CAT-5 solution was the ticket for us.
__________________
Ted R. Ruiz Sr.
Ad-Venture Video Productions
www DOT editbay DOT tv
ted is offline   Reply With Quote
Old 04-23-2008, 10:33 AM   #10
jh4wvu
cat5 solution versus standard cables
I was hoping for a single cat5 solution...thought a system from Vaddio was the answer but it still requires three cat5 cable runs...one for the video, one for the power, and one for the control.
I am going to be using 3 Sony BRC-300 cameras in a portable application. Power would only need to be connected at each camera, one VISCA cable for the camera control, and one BNC cable for video.
This seems cheaper to buy these cables rather than paying for the CAT5 solution and still having to buy 3 cables for each camera. I will probably spend a couple of hundred dollar on these cables versus $3,000 on the Vaddio solution and still have to buy a whole bunch of Cat5 cables.
Any thoughts on the true advantage of going with a cat5 system?
jh4wvu is offline   Reply With Quote
Old 04-23-2008, 09:53 PM   #11
TRCC
TRCC's Avatar
Jef, Did you ever get any pictures of your boxes? Right now we're using EXTRON MVS series, but to get a tally/intercom integrated makes me very intriged on your products. I'd like to see what they look like. I'm also interested in the CAT-5 cable that wraps, we're using regular CAT-5 cable with an XLR sleved in 1/2" Nylon stretch tubing to conceal/protect, but we constantly have to replace both cables because of twist and kinks.
Thanks,
Luke
TRCC is offline   Reply With Quote
Old 04-23-2008, 11:55 PM   #12
ted
ted's Avatar
The last day of NAB I found the "near perfect" solution.
CAMPLEX has on one, yes ONE cat 5 cable, High Def component video, Tally light, I'm pretty sure stereo audio, power to the camera and I think more.
The "near" perfect part is that they won't be out till June-September and the box runs $5,000.00 per camera.
But man oh man, this is truely a great option and all on one CAT 5 cable.
Camplex is doing great things in this department. It won't be long before others figure this out and the price drops.
I'm still waiting for my system from Jef so I can't tell you how that's working out yet.
__________________
Ted R. Ruiz Sr.
Old 04-29-2008, 11:34 PM   #13
MacOne
Cat5 Connections
Jef,
Interested in your cat5 connection cable system also - please post pic or more info..
Thanks,
Bob
Mac One
MacOne is offline   Reply With Quote
Old 05-02-2008, 10:40 AM   #14
BELLE1RaceComm
Pics
Quote:
Originally Posted by MacOne View Post
Jef,
Thanks,
Bob
Mac One
Im very interested in the pics too....I think we might need to convert our 3-4 Cam set-up with this.
__________________
Sight.... Sound....and Vision through Speed......
BELLE-1 Racing Communications
BELLE1RaceComm is offline   Reply With Quote
Old 05-02-2008, 10:36 PM   #15
ted
ted's Avatar
Bob and Belle, get in line. I'm still waiting on mine. I'm sure it'll be great when it gets here though. I'll let out a few [ictures when I get it.
__________________
Ted R. Ruiz Sr.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright 2000-2007, NewTek
