Go Back   NewTek Discussions > LightWave 3D Support > General Support
Reply
Thread Tools Display Modes
Old 10-01-2008, 04:45 AM   #1
jeromedeverite
interpolated render probleme
Hello... sorry for my so bad English
Then, here is the problem , the interpolated render of 9.3 ,9.5 is not really accurate when we are in the presence of chalk-lining in the shade(shadow), (in fact a groove of some centimetres in a volume).
When it is directly enlightened there is no problem (see exemple, for one is interpolated, the other is a correct render but with Monte Carlo)
In fact it is necessary to push the regulation really far kind , like mps=0 mes=0 and whith high A-Aliasing to have something which does not drool (almost), but we lose all the saving of time of an interpolated render.
Any solution???
thanks
Click image for larger version
Name:	EXEMPLE RENDU.jpg
jeromedeverite is offline   Reply With Quote
Old 10-01-2008, 07:27 AM   #2
3DGFXStudios
Space Monkey
3DGFXStudios's Avatar
babelfish huh?
__________________
3DGFXStudios is offline   Reply With Quote
Old 10-01-2008, 07:49 AM   #3
Mitja
I'm not a squirrel!
Mitja's Avatar
What are your radiosity settings?
Mitja is offline   Reply With Quote
Old 10-01-2008, 08:12 AM   #4
jeromedeverite
I join you one scene 9.31 , juste one light, no materials, it's just for example
the settings are hight ( i think)
interpolated radiosity - monte carlo
-directional ray ( on)
rpe 180
MES 5mm
MPs 0
camera settings - perspective
AA =8
adaptive sampling 0.05
Old 10-01-2008, 08:56 AM   #5
Mitja
I'm not a squirrel!
Mitja's Avatar
I'm checking the scene right now, but you want to render with 9.3 or 9.5?
Old 10-01-2008, 09:19 AM   #6
Mitja
I'm not a squirrel!
Mitja's Avatar
Some things I came across:
Delete all 2-point polys and merge points, in modeler.
2-point polys are evil!
In layout: change the light to something different than a distant light (area perhaps?) and set the falloff to inverse square (real light falloff) and set to 0 the ambient light.
This won't affect the "splotches" you are having, but it'll help with realism.
Those artifacts are due to radiosity settings, but since I still don't know whether you'll be using 9.3 or 9.5 I can't help for now.
Maybe 8 AA passes are to high, 4 should be more than enough if you lower the AS to 0.03-0.04. The MPs od 0 isn't so good too.
I'll help more when I'll know if 9.3 or 9.5!
Cheers!
Old 10-01-2008, 09:20 AM   #7
Mitja
I'm not a squirrel!
Mitja's Avatar
And yeah, I was forgetting... nice model!
Old 10-01-2008, 10:21 AM   #8
jeromedeverite
thanks Mitja, in fact i've test to render it with 9.3 -9.5- and 9.51 , and in none of them i've good render, always ' splotches".
with 9.3 it will be ok
Old 10-01-2008, 12:09 PM   #9
MooseDog
Dreamer
MooseDog's Avatar
hope the attached picture may help.
the settings are getting close, but there still is some blotchiness. i did not deal with the non-planar polys though, so that may be a factor.
tested on an old p4 . i figure that if i can get close on that box, it should rip on the newer one. render time was under 8mins.
bien fait le model, bien fait
__________________
We are pirates, we are artists...
Blog
MooseDog is offline   Reply With Quote
Old 10-02-2008, 02:22 AM   #10
jeromedeverite
thank to spend some time for help me
As you can see, it is not so easy to have an appropriate render in that case , but in the city where I live arras (the North France) it is often this style of architecture (but i I like, lol).
With 9.5 by pushing settings
intensity =100
IB = 1
RPE=180
angular tolerance= 45
MPE= 0.5
max PE= 100
Multiplier= 200
I have not too much " splotche ", but render times grow longer
Old 10-02-2008, 05:24 AM   #11
MooseDog
Dreamer
MooseDog's Avatar
http://www.except.nl/lightwave/Radio...de95/index.htm
very helpful for understanding these settings. maybe you've seen it though.
in my expereince, when the mpe drops below 2, render times grow.
also, try the multiplier at 50%. still works very well!
bonne chance et merde
__________________
Blog
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright 2000-2007, NewTek
